building shower pan
bob young
Member Posts: 2,177
brooklyn plumbers are not capable of making a shower pan ???? what is this world comming to ?
I am involved in a big home rehab project. All new inhouse water piping (using PEX), radiant heat (also PEX), mega bathrooms with site built shower liners, etc. The contractor has built 1 shower with a "outside" corner, approx. 225 degrees. How do I construct the liner around the corner. The blue vinyl does not stretch that much,you can't overlap and glue weld enough to make me feel safe, the factory rep. has been unable to help me, and I have not been able to find a preformed corner. Any suggestions?0 -
It may sound old-fashioned, but why not use sheet lead or copper?0 -
Hot Mop
Sounds like you need a hot mopped pan..0 -
EPDM
Custom shower pans are usually formed with EPDM, available at most supply houses. The pan should be installed 6" above the flood rim, with no nails or fasteners, below the rim. Years ago, Fine Homebuilding did an article about the correct intallation of the material years ago...maybe it's in their archives. "Old-timers" (myself included) used sheet lead, but the cost is prohibitive, and the plastic doesn't react with brass shower drains.
lead vs. vinyl
We do them with lead all the time so you should be able to do it with vinyl in your sleep. hire a carpet layer. he could do it for you. or a plumber. use a smith type drain & put a 24 hr. test on pan. you can do it.0 -
try
ardex 8+9 or laticrete 9235..i miss the west coast where we always had them hot asphalt mopped.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
Shower pan
Check out Schluter.com. Kerdi sheet membrane for pan and wet walls.. Also Tile your world forums. Great resource.0 -
In my area ( Brooklyn NY ) if the corners are not square i call in a fiber glass guy, they lay the membrane and the resin smells for a day but well worth it. Cost is very,very resonable.0 -
Try it, youl like it0 -
sign me up!
stevex sounds good,sign me up .Also a plumber in your neck of the woods and have to make vinyl pans regardless of shape or size.So please tell who is your very ,very reasonable fiber guy and how do i contact him?0 -
Shower Pan Construction
Guys
Take a look here www.noblecompany.com We have a shower sectionthat also has short videos on construction. Hope this helps.0 -
His name is Sam and # is 631-960-56700
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 965 Plumbing
- 385 Solar
- 15.3K Strictly Steam
