Fly Ash
hr
Member Posts: 6,106
is a common ingredient in concrete just about everywhere. It is inexpensive and plentiful. Most is a byproduct from coal fired power plants.
It's very common in hot climates as it makes the job easier to finish.
I doubt the fly ash would harm the modern plastic tubes.
Typically fly ash from high sulpher content coal could be an issue with older steel and copper tube radiant systems. But only if it was in a wet location would the ash get aggressive towards the ferrous metal, or copper.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
Fly Ash
is what the architect wants to use in the concrete slab in a "Green Building" project here in Berkeley. I'm concerned that it might be caustic and damage the PEX tubing. Should I tell them no?0 -
manufacturer say?
whats the manufacturer say? go to the horses mouth!
off hand I would think that only solvents of similar chemical composition will degrade pex, along with sun light.0 -
I would do this
Find out from the architect what percentage or at what concentration the ash is going to blended into the mix. Then check with your tube manufacturer. I don't think it'll bother the pex but any metals in contact may present some issues.0 -
Fly Ash
Thanks, guys. Much appreciated.0 -
The fly ash
content makes a difference if the owners are going to use an acid stain finish on their concrete...so I am told by the Kemiko rep. anyway FWIW
Nick0 -
Boy, you would have to get a hellva lot of flies to make much ash wouldn't you? I'd imagine a fly when burn would make much ash.0
- 167 Indoor-Air Quality
