1 cold steam rad 2 pipe system
John_102
Member Posts: 119
Where? Steam symptoms aren't necessarily where steam solutions should be.
1 COLD STEAM RAD 2 PIPE SYSTEM / ALREADY CHANGED TRAP0 -
OPEN VALVE?
Changing the trap
on the cold rad won't help if the dry return is being pressurized by another bad trap or a bad vent. I think you might have some type of Vapor system there. Have you seen any manufacturer's info on the original traps, valves or any hardware around the boiler?
