1 cold steam rad 2 pipe system
John_102
Member Posts: 119
Where? Steam symptoms aren't necessarily where steam solutions should be.
1 COLD STEAM RAD 2 PIPE SYSTEM / ALREADY CHANGED TRAP0 -
OPEN VALVE?
Changing the trap
on the cold rad won't help if the dry return is being pressurized by another bad trap or a bad vent. I think you might have some type of Vapor system there. Have you seen any manufacturer's info on the original traps, valves or any hardware around the boiler?
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
