D'mand Hot Water Systems
Joe Mattiello_2
Member Posts: 94
Taco Dmand pump will work fine with a tank less heater. Push the button to energize the pump and the heater turns on producing hot water. Always consider the pressure drop through the heater when sizing the dmand pump. This could be the problem youre referring to with the on the demand system. Pressure drop through the tank less heaters are typically higher and low head pumps will not have enough capacity to trip the pressure switch energizing the heater, so the pump runs but the heater doesnt. Taco recommends the 0011 Dmand pump with tank less heaters.
Joe Mattiello
Technical Support Technician
Tel. 401-942-8000 X 484
Fax. 401-942-2360
1160 Cranston St
Cranston, RI 02920
joemat@taco-hvac.com
Joe Mattiello
Fax. 401-942-2360
1160 Cranston St
Cranston, RI 02920
Anyone, had experience with problems with Taco, Metdund, and Grundfos
D'mand hot water systems, also how well do they work with Rinni and other
tankless water heaters. thanks chris0
- 129 Chimneys & Flues
- 122 Geothermal
