Radiant walls in basement
Weezbo
Member Posts: 6,231
around the exterior of the concrete would be a benifit.
Radiant walls in basement - Insulation
Just a question....What is the recommended procedure for radiant walls and insulation in a basement....I have 8" thick poured concrete walls, then 1/2 vapor barrier foam board, then 2x4 studs....I plan on screwing aluminium plates to studs in a vertical fashion and running 3/8" PEX through the plates, approx 10" centers....I've been looking at standard paper faced fiberglass insulation, but seem to remember reading that paper faced may not be a good selection....What should I use? Unfaced? Foil faced?0
- 129 Chimneys & Flues
- 122 Geothermal
