Anode rods
gerry gill
check this site out for water heater info..very learned man there..http://waterheaterrescue.com/
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=360&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
gwgillplumbingandheating.com
Bad taste in the water...
Can the anode rod cause bad tasting water?
There is no noticeable smell but the taste is strange.
It leaves a dry feeling in your mouth. The pipes are all copper so I don't think that has anything to do with it.
It does get a little better if we leave the water run for a few seconds.
Any ideas??
Bergy0 -
The anode rod would only affect the hot water. So, unless you're drinking the hot water, something else is causing your problem. Find a local lab, or water treatment company and have some water testing done.0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
