Expansion tanks
Jim_4
Member Posts: 6
When changing out a customer's boiler, what (if any)
advantage is there to removing the old steel expansion tank that is still in good shape, "with an airtrol fitting" for a new diaphragm expansion tank?
Jim
I would keep it. You already have the Airtrol fitting and that's a big plus. You will never have to worry about a diaphragm blowing out....That's a Keeper;-)
Mike T.0 -
if the ceiling
If the ceiling is taller than normal, tank out of the way of customers walking around, I'd reuse the tank. Otherwise, I junk it due to airtrol sticking too low to scrap some skin and hair from ur head.... Remember, to PUMP away from the tank!0 -
Age
One down side is you still have a 30-60 year old tank hanging up there...I guess you can switch it over later when the old tank leaks..0 -
You cannot use a micro-bubble ar eliminator in conjunction with that old tank. If you desire a Spirovent or similar product, you would then have to install a new diaphragm tank.
- 120 Geothermal
- 394 Solar
