One I've not run into...........
S Ebels
Member Posts: 2,322
Ancient Bard oil furnace with a (Wayne?) burner model MP-98. The motor is shot.... the problem is the motor flange on this old girl is about a 1/2" larger diameter than a normal burner motor.
Are these larger diameter motors still available? It's so rusted up I can't tell if it's 1725 or 3450 rpm. (this old babe has been doing yeoman's work in a dairy barn for 35 years) Obviously the motor numbers have also succumbed to brown rot or I would post them. There are no supply houses open at 11:30 PM so I can't call and find out. Therefore, I seek the knowledge of the WALL. Anyone awake yet?
Check out ......
The fuel pump numbers. If you can still read them, you'll get your answer.(unless it has been replaced by a dual speed competitors replacement) Best of luck. Chris0 -
i am awake....its early *~/:)
do you have the time to describe the coupling to the pump? i am inclined to think it is 1725 what pump does it have the numbers on it might say right hand rotation? i am not good at typing stuff:(0 -
I've seen them
lots of 'em. probably threw most of them away. I'll check my bonepile today and see if I can glean some info for you. I'm sure it's 1725, too.0 -
It's probably a 1725 rpm,
N Mount, Carlin makes an awesome replacement motor.
http://www.carlincombustion.com/products/pscmoter.htm0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
