Boiler net ratings
DanHolohan
Member, Moderator, Administrator Posts: 16,620
<a href="http://www.heatinghelp.com/newsletter.cfm?Id=64">Boiler Ratings</a>
Retired and loving it.
Oil hot water boiler size
I think I understand net ratings. I usually do not think about them. I typically work with commercial systems which have pipe insulation. For that matter usually two slightly over sized boilers are used.
I am looking at a new single family residence with radiant heat which needs an oil fired boiler. The house load is about 115MBH. Should I size that boiler based on the gross output or should I count on some losses?
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
