How low can I go?
Probably a dumb question, and probably the answer is somewhere simple... but this is quicker, and you folks are great!
I have a nice big Weil-McClain boiler, controlled by a Vaporstat, on a nice big Hoffman (complete with differential!) vapour steam system. Question is: how low can I set the Vaporstat? I know, the lower the better, but there must be a limit? Opinions on what the two controls should be set at welcomed...
Thanks!
Jamie
  • DanHolohan
    DanHolohan Posts: 16,735
    I wouldn't go lower than
    four ounces on the cut-in. Try 10 ounces on the cut-out.
    Retired and loving it.
    Jamie Hall Posts: 27,834
    limbo dancing
    Thanks Dan! I'll try that -- actually I'm a little lower than that now (9 oz on the main and 8.5 oz on the differential, which says it's subtractive)
