Combustion analysis question
Aside from O2, CO2, CO, draft, smoke test and net stack temp in the breech, why would a CO2 reading "over the fire" make sense? Seems to me that a reading taken there won't add anything of substance and may well be dilluted by free air.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=98&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • jim sokolovic
    jim sokolovic Member Posts: 439
    It could tell you...
    if there is significant leakage around the boiler sections and flue collector. The CO2 in the breech would be the diluted reading, in that case?
  • Rudy
    Rudy Member Posts: 482
    Getting accurate stack readings
    Yep, you might want to take an O2/CO2 reading over fire (with the opening sealed with aluminum foil or something) and compare it to the stack readings.
    I've found that in a tight system the stack reading will normally be about 1/2% higher.
    Any more difference than that indicates that there is alot of 'tramp' air being sucked in though cleanout ports, access doors, etc. and the stack reading is not accurate.
Welcome
It looks like you're new here. Sign in or register to get started.
