New radiators
Junk shops, scrap yards, salvage companies frequently have them on the cheap as long as you don't mind spending the time to get them looking decent.
Check with plumbing/heating firms. They often build a stockpile. They'll frequently sell as long as there hasn't been a recent unusually cold winter...
New ones are available from Burnham. Here's the link: <A href="http://www.burnham.com/radiator/index.cfm">Burnham Radiators</A>
  • Scott Brink_2
    Scott Brink_2 Member Posts: 21
    Where can I find radiators
    I need to replace a radiator in my house for a remodel. I have a one pipe system. Any ideas on where I could find a steam radiator supply to puchase a new radiator?
    Jamie Hall Member Posts: 25,707
    you can get them new
    There are at least two folks who make new ones -- Burnham is one, I think, and Governale.
    They ain't cheap...
  • Joel_18
    Joel_18 Member Posts: 18
    available rads
    contact me with info on the radiators that you need. I can most assuredly help you.
    radiators@rcn.com
    cheers
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    If your looking
    For something modern looking for the new room, try steamradiators.com. They appear to be a subsidiary of Runtal. We've used a few and boy do they put out some heat for their size.
    The ones I've personally used were 2 pipe set up, but the units can be mounted and piped in any configuration. Be sure to get an accurate heatloss for the addition. Good luck. Chris
