Inground tank testing
Would like to do inground oil tank tank testing. What is the best method
  • Ken_8
    Ken_8 Member Posts: 1,640
    That depends
    There are many ways, all bordering on black magic and witch-craft.
    The problem is not testing the tank - as much as the piping attached thereto! The fill pipe, the vent pipe and the oil lines are the problem more than half the time. Simply plugging the vent, the fill and the oil lines, and then pressurizing the tank with a couple of pounds of pressure and seeing if it holds will NOT prove what's leaking - if one exists! From the obvious solution of isolating all elements (the tank itself, the fill, the vent and fuel lines) one can determine if there's a leak and where.
    If it gets ugly, monitor wells at the four corners of the tank (in the dirt surrounding the tank and down about 4-8 feet below grade) are frequently done to verify UST integrity. The problem is, if the oil guy was a slob while filling the tank and drooled a few ounces near the fill, over the years, a few ounces can suggest to testing monitors a leak - when in fact it was sloppy fills - not tank leaks that caused the problems!
    Like I wrote, UST "testing" borders on black magic and witchcraft...
  • Mijola
    Mijola Member Posts: 124
    Tank testing
    Do you suspect that you have a leak or are you just testing to be cautious?
    Ed Carey
  • oil-2-4-6-gas
    oil-2-4-6-gas Member Posts: 641
    is this your tank or tank testing as a business??residential or commercial?
    Jamie Hall Member Posts: 26,761
    Black art
    well, not really -- but to do it right, it takes a good bit of training and really good equipment. As someone said, the leaks are most often in the piping -- particularly the swing joints. And even with a clean tank test, you can't be absolutely sure that there are no leaks (I've seen it) and that the ground is clean.
    If you intend to do it as a matter of personal curiousity, go for it, but the equipment isn't cheap. If you plan to do it as a business, keep in mind that the insurance (errors and omissions) is hideously expensive!
  • Kyle Kubs
    Kyle Kubs Member Posts: 12
    Tank testing
    If your looking to get your personal tank or one in a prospective home tested, there are many companies that do this professionally. It typically costs about 350 - 400 dollars and is considered to be 99.95% accurate. The new computerized equipment is supposed to even pickup a pinhole. "Pressurizing" an oil tank is no longer allowed, for obvious reasons... The new test is done by applying suction. A computer then "listens" for specific frequencies of sound that would indicate a leak and even differentiate between different areas of the tank.
    Take a look at this website - I use these guy's on a regular basis
    www.tankinspections.com
    Good luck
    Kyle Kubs
    Benchmark Home Inspection Services
