Steam break
Glen
Glen Member Posts: 854
my thoughts too.
  • Glen
    5 pound steamer
    One of our local hotels as this wonderful steamer in the basement. All rads are cool - it's not achieving pressure, feeding constantly & the burner is on constantly. After a bit of sleuthing I told the maint guy that he had a steam break - turns out its under the bar in a crawlspace. Had to chain saw a trap door in the middle of the bar. 4 inch main, 103 years old. So the question is this - do I drag down the geared threader and thread a pup or do I drag in my friendly rig welder. What are my chances of repairing this given the age of the pipe??? I'm thinking that after all this time - the pipe may well be very thin and not suitable for threading. Any ideas????
  • oil-2-4-6-gas
    oil-2-4-6-gas Member Posts: 641
    you won't be threading that 1 --break out the welder replace as much as you can see and access --
  • bob young
    bob young Member Posts: 2,177
    copper liner
    if it is a straight run without branch connections maybe you could slide copper inside and connect on both ends
    Steamhead Member Posts: 17,636
    Consulting
    Jamie Hall Member Posts: 25,708
    Amen
    chances are if it broke once, it's going to break again; been there, done that... replace as much of it as you can.
