Cold steam radiators...what next to look for?
gerry gill
Member Posts: 3,078
that the radiators have a slight pitch back toward the inlet valve..you may have to shim the opposite sides legs to achieve this...
gwgillplumbingandheating.com
some cold radiators in steam system...what's next?
When I first turned on the system this year, all steam radiators were piping hot. Within a week or two, half were cold, although the base of the pipe below the intake valve (for most of the cold radiators) is still piping hot. I've replaced the vents on those, which didn't help. I've drained the water (dirty) from the system and refilled it (twice) to the halfway point in the glass guage. Not sure what to try next. Does the fact that each radiator only has one pipe going into it make this a one-pipe system or is this determined elsewhere. Obviously, this is my first intro to steam radiation... Any suggestions would be well worth it.0 -
Go to
Books and more.....and look for this book
http://www.heatinghelp.com/shopcart/product.cfm?category=2-109
Are the valves open at the radiator inlet?
Which of Dan's 2 books
I've traveled all over the net today, and have run into links all leading back here. Dan seems to have the two books, the one you mention (We Got Steam Heat) and A Pocketful of Steam Problems. If I had to choose one, as a new homeowner, which is best?0 -
books
From one homeowner to another get We Got steam Heat and then invest in Dan's "The Lost Art of Steam Heating" and the EDR book (Every Darn Radiator). With these you can educate yourself, scare every contractor who wants to work on your system away EXCEPT the true professionals who know what they are doing, and probably save money in the long run. It worked for me.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
