radiant heat question
Pat_11
Member Posts: 50
If I have a snow melt system design for 125BTU/sq ft @ 90*water. How will my BTU output change as water temperature is increased? Just curious.
Math quiz
Snow melt differentials are generally based just above freezing. Here your 90F water gives you a differential near 58 or about 2 btuh/sq.ft/degree differential. Increasing the entry temperature (at the same flow rate) will give you a linear increase in your output until you start to return above freezing, then you are back to 1 Btu/lb/degF divided by fluid density. Enjoy....Dan
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 973 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
