Boiler size
Paul_28
Paul_28 Member Posts: 113
I calculate a heat loss of 82000 BTU/HR using Slant/Fin software. I am planning to use a boiler with a heat output of 85,500 BTU/HR. The next larger size is 110000 BTU/HR. The system will include a 40 gal DHW tank. I am concerned with short cycling, which boiler output is best. Thanks Paul
Welcome
It looks like you're new here. Sign in or register to get started.
