Finding cracks in furnace heat exchanger
Jim Mueller
Member Posts: 8
This a gas Olsen dualmatic 80,000 btu furnace, and could you explain what kind of damage this can cause.
Explain if this is the right way to check a heat exchanger
I would like to know what are all the proper ways to check a 20-year-old furnace heat exchanger for cracks? Consumers Energy sent a company (Greater Detroit Heating & Cooling) to check my furnace for a noise it was making from my blower motor. When he was looking at it, he decided that he wanted to check my heat exchanger for cracks. He poured a large amount 4(64oz.) bottles of cold water into a running, hot heat exchanger. Is this the correct way? Do you think doing this would damage or crack the heat exchanger? If you think it would cause a crack please explain WHY or HOW. Your response and any help in this matter would be deeply appreciated.
James M. Mueller
jimmueller@wideopenwest.com0 -
Huh?
My thought on the matter is use a smoke bomb and or pepermint oil. if you just want to find out in a hurry and inexpensively.....a tech will have mirrors and tools that leave no question in thier mind wether or not you have a crack in the heat exchanger.
The method you saw employed i must say i am unfamiliar with....perhaps you could further explain the out come of the techs actions....it would suprise me if it didnt land him on his back one day , there is little armour that holds up well to 11,000 volts. you are refering to a oil fired furnace correct?0 -
Jim,it is an unconventional use of testing heat exchangers.
Olsen
Mr. Mueller.
My name is Mike Breault and I work in technical Support at the Olsen Division of ECR International. Please feel free to give me a call and we can discuss your problem. I can be reached toll free at 888-270-8324 ext 228
Mike Breault0
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 966 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 44 Industry Classes
