pex size to re-pipe radiators
Tom Giedraitis
Tom Giedraitis Member Posts: 44
I have discussed re-piping my existing steam radiators to convert them to hot water with two contractors. One insists that 3/8 pex is perfectly adequate while the other insists that it should be done using 1/2 tubing.
Both intend to set each rad up on a separate loop off of a manifold.
None of the rooms requires a single radiator output greater than 3500 Btuh.
What does the wall recommend?
Welcome
It looks like you're new here. Sign in or register to get started.
Welcome
