Weezbo
S Davis
S Davis Member Posts: 491
It sounds like you have a problem getting new product up there, where are you located? I am 60 miles north of seattle and 60 miles south of the Canadian boarder.
Maybe I could help you get what you are looking for( Taco Mixing Block etc.) as the supply houses around here are pretty good about having new product.
The Mixing Blocks are 1 day out from ordering here.
S Davis
Apex Radiant Heating
  • Weezbo
    Weezbo Member Posts: 6,231
    That is a fantastic offer....
    I originally dropped in to ask about some materials made by poly comfort called poly dynamic and poly therm.one is a system of laying in what looks like blue plastic vynil sheets on deck,these sheets have deformations or extrusions depending on your preference that are in the form of the bottom half of an egg carton for a dozen eggs. The wirsbo or rehau snaps right into these deformations allowing considerable flexability in piping arrangement,these sheets are self interlocking. once the pipe is laid in the gypcrete goe in,this requires about 1?2 the normal amount as the deformations have "air" in them,the water doesnt go into the flooring materials there fore saving somewhat on the moisture abatement issues...because there is some what less thermal mass it more quickly accelerates as far as radiant cement /gypcrete /cement sand slab systems go...it also aids in the drying and curing time for these systems so there is a bout 1/3 the wait to cure date.. the other products are for wall and ceilings...these interest me for i am definitely into the idea of space conditioning economically and at a standard quality level. Bekotek is a similar product and it looks a bit more expensive and time consuming for the quality level to which it attains.i am not knocking it however it seems to have a tribe of gizmoes that go with it and honestly i am not looking to dragaround lots of bits and pieces over and above the countless product that already go into new construction .i'd even consider some information in the way of a track record on the poly comfort products...I am unable to even come up with that to date.England has it. like how difficult can it be for someone in America to make the stuff?:)sorry i digress. thats a great offer if you see these blue vynil sheets hey I am interested....
Welcome
It looks like you're new here. Sign in or register to get started.
