water hammer and spring valves
I live in a 100 year old apt. building with steam heat and the landlord has used the "it's just old" excuse for water hammer for the last time. I have a radiator that I have "shut off completely" - we don't need any heat in that room due to overall building heat. It's two feet from my head in the bedroom and it has severe water hammer - and I can tell the difference between pipes banging in the building and someone hitting a sledgehammer on a pipe 2 feet from my head. My question is - if I really have the valve turned off completely how can I be getting water hammer at that valve? There is a 15lb valve on the radiator - is it possible that even with it fully closed that the valve is opening momentarily under pressure causing a pressure drop - rapid steam formation - followed by water hammer? (too much pressure/bad valve)
There are certainly other people on the same steam "riser" as I'm on - is it possible that their valve settings could be causing water hammer at my completely closed valve?
I've read everything under "Steam Problems" but since I don't own the building I'm limited by what I can check. The landlord's plumber is coming over and I'm going to talk with him and want to be sure I'm as prepared as possible so I don't get the "well, it's just old" excuse. I'm an aircraft mechanic and if I used that excuse for not fixing stuff there would be a lot more dead people than there are. Any ideas?
Thanks - Dave Jacopille, Brookline MA
    Jamie Hall Member Posts: 27,699
    Bang whang...
    It may not be water hammer in that particular pipe. It could be from the riser... (trust me, been there, done that, have the T-shirt). Is there a long horizontal runout to the riser in the basement? Could be at the elbow to the riser at the end of that. Amazing how sound travels in an iron pipe...
