help to freakin hot
coop
Member Posts: 3
I installed a buderus boiler with the logamatic control with 2000 square feet worth of hepex I have 6 different loops with circulators,mixing valves and checks on each loop now the problem is the house is to freakin hot. I have balanced each loop from the design temp on the loop layout sheet .still the same also I have only one room sensor in the house it seems to be fine anybody with any input would be greatly appreciated coop
Boiler temperature
Did you try lowering the heat curve number ? It is call something else(reference number?) but it is the boiler temperture needed to heat the house at 14 degree. Do you remember reading it ? The sensor is only for fine tuning and is set from the factory from within the control to swing 5 degrees either way...It can be adjusted but I don't think it's recomended....
P.S. Did you install thermostats as a "High Limit" ?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
