Gyp-crete question...
Scott G.
Member Posts: 15
What's the going rate for gyp-crete in your area? Is it sold by the square ft.? Thanks, also how soon after its poured can foot traffic walk on it?
Thanks... Scott G.
Thanks... Scott G.
Dpends on...........
square footage, say 1500 to 5000. Around here, it seems, $3.30 to $2.50 p/sq ft is a good ballpark figure. I would opt for Therma Floor products (Gypcrete brand name) over Hacker Industries. Nicer floors, at least in my experience.
It can be walked on the next day, but it should be covered with luan or plywood if heavy foot traffic is expected. No ladders, scoffolds, etc. unless on plywood. It takes 7 to 21 days or more for the slab to complete cure. Remember, a gypsum floor is not a wearable surface and has to be sealed before finished floor is installed.
gypsum floors
hb
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
gypsum based underlayment...
We have had tens thousands of square feet of Gypcrete poured
over the last 13 years, alot of it unfortunatrely with
limited success. If you can find a LEVELROCK applicator in
your area give it a chance, truly impressive product and
screened and trained applicators, and competitive $$$.
After a day it is as close to flat work as you will find,
because they can pour it at 3,000 psi + also.
Good Luck
Big Al0
- 62 Biomass
- 114 Geothermal
