snapped bolts
BillW@honeywell
BillW@honeywell Member Posts: 1,099
Love that WD40! I also can vouch for the Craftsman screw extractors. I had 20 windows with 20 or so bolts to remove from the train car last year...some broke or were rusted so tight that they had to be dealt with with extractors. "Mr. Hot Wrench" was not an option in that case, though.
  • Gary Usa_2
    Gary Usa_2 Member Posts: 45
    snapped bolts
    hiya guys,as i have started to work on boiler coils and the great delight of the bolts snapping on me,please would you be so kind what the best way to remove the snapped bolts please.
    hope all is well
    thanks
    all the best
    gary usa
  • George Berkeley
    George Berkeley Member Posts: 40
    Hmmmmm
    Are they flush or do you have any shaft left for a grip?
  • Gary Usa_2
    snapped bolts
    the bolts as always snap clean flush with the cast,or not enough to get any vice grips onto it.
    all the best
    gary usa
    Jamie Hall Member Posts: 26,835
    Easy out
    Perhaps the most clearly mis-named tool in my tool kit. However... if the danged thing snapped and left you nothing to grip (it happens on engine blocks all the time...) they are great: you drill the correct size in the centre of the bolt, then run in an 'easy out' to match (turns left and grips -- trust me!) and out she comes. Good penetrating oil helps...
    jamie
  • Gary Usa_2
    easy outs
    where would i get them from please,i think what i need to get is a tap and die set,what would be a common range of taps to get please.i assume then you would have to drill the centre of the snapped bolt out in order to get the easy out inside the snapped bolt,
    all the best
    gary usa
    where to get them...
    Auto parts store. You do drill out the centre of the snapped bolt (if the bolt broke unevenly, you may want to grind it flat, and use a centre punch to get the drill started); there are easy outs for various size bolts, and each has a recommended drill size. Some kits even have drills which are meant to go with them. If you can get the bolt out -- which you probably can -- you shouldn't need a tap, although it wouldn't be a bad idea to get a tap set with taps sized for the bolts and to run them down the threads to clean them up after you get the remains of the bolt out. This help?
  • Gary Usa_2
    thanks
    very much for the help i was searching the snap on catalogue at the items you said about so many to choose from ,they call them screw extractors,i assume they mean these to be used with bolts.i was thinking about snap on because of the quality ,are the other really good names out their as i didn;t wish to buy any items that may just snap on me,
    thanks very much for the help
    all the best
    gary usa
  • D lux_2
    D lux_2 Member Posts: 230
    I have
    brazed a longer bolt to the stub takes 3 hands , but with the heat of brazing they tend to turn out ok . You can still drill out if it doesnt work . All so there are left hand drill bits for drilling out the stub .
  • Tony Conner
    Tony Conner Member Posts: 549
    The Best Ones...
    ... I've seen are from Snap-On and MAC. They have a nice big hex head so you can get a socket or box end wrench on them, and a relatively short spiral section to grab the hole drilled in the broken bolt. Shorter means harder to break off. They come in a whole range of sizes.
  • Tom M.
    Tom M. Member Posts: 237
    useful tools
    Channelock makes a tool called a nutbuster. It looks like regular channelocks but has an angled upper jaw and a convex lower jaw and larger teeth for gripping. becase of the design, you get more of a squeeze on the bolt as you push or pull on it. Sometimes the material is too soft and the teeth will just rip into it. I've also gotten some out with a 6" pipe wrench. I would also recommend running the tap through all of them as someone said above. Everhot replacement coils come with studs and brass nuts so life will be easier if the next guy to do the coil or the gasket is you.
    Snap on
    Top of the line -- they don't break! Yeah... screw extractors.
  • maintenance-guy
    maintenance-guy Member Posts: 2
    If you don't mind a post from another trade: I fix alot of machinery and have this happen quite often. 1) Use penetrating oil and let it sit for a few minutes. 2) Heat helps loosten stuck bolts before they break off. I'll warm a really stubborn bolt with a torch and then turn it out hot. 3) Easyouts work sometimes but It's often a fight. 4) If you have even half a thread left sticking out, try to thread on a nut, just so its barely hanging and you can weld the nut to the stud inside the nut. This new "head" along with the heat of welding works really nice. 5) Drill out the bolt and tap to a larger size or tap with a helicoil kit and insert the a helicoil so its the same size as before. 6) As a last resort, drill the bolt out just leaving the threads and pick the threads out. It's really hard to drill in the center without doing it on a bench press though.
    Broken bolts suck. Good luck.
  • Aidan (UK)
    Aidan (UK) Member Posts: 290
    Be careful
    Be careful with the screw extractors, Gary. They're made of very hard steel and if you break one of them off, you'll be up the proverbial creek.
  • Earthfire
    Earthfire Member Posts: 543
    Extractors
    Sears also sells the extractors & easyouts.Easier to get to then a snapon truck. but get only craftsman (warranty). As for replacements for coil studs a good coil supplier should have some in stock . My coil maker has studs that are pipe thread one one end . You use a 1/8" or 1/4" pipe tap on the boiler, a little pipe dope, install stud and no leaks, (taper threads seal tight)
  • Colin
    Colin Member Posts: 50
    When you finally get to reassemble........
    don't forget to use some Permatex (sp) anti-siese compound on the threads. It sure helps the next time you or anyone else has to take it apart. Just don't lick your silver fingers afterwords.
    Colin
  • Marty
    Marty Member Posts: 109
    rustbuster
    mars sells something called rustbuster hvac supply place that deals with mars stuff usually has it comes in a bottle like the zoom spout oil ones. The stuff is great even better than wd40. As far as easyouts any decent hardware store will have them, I tape the right size drill bit to the easyout so on the rare occasions I need to use one the bit and easyout are togather no trying to read what size bit off the shaft.
  • BillW@honeywell
    neverseize
    I did use it on all the replacements, and my hands looked like the Tin Man's after. Those windows probably won't ever be redone again, but if they are, the guy who does them will thank the "Dead Man" who replaced them in 2002!
  • PJO
    PJO Member Posts: 140
    Neverseize Testamonial...
    In 1994 we were replacing 36" valves on a cooling tower. The original valves where installed in 1953, and had some form of anti-seize on the bolts...didn't look gray but who knows after 41 years in nasty water and the surrounding air?
    The bolts (about 1" diameter) were embedded in the concrete wall of the tower, and the nuts turned off them with a 36" pipe wrench and one man with the threads in pristine condition...all 48 of them! The mechanic was amazed.
    New valves where installed in no time using a hoist, instead of having to play with the original bolts...after a good layer of anti-seize.
    PJO
  • John Abbott
    John Abbott Member Posts: 361
    Kroil
    The worlds finest penetrating oil by a large margin is called Kroil and is available from Kano Laboratries Nashville Tenn. 618-833-4101.The stuff is so far ahead of anything on the market its incredible.By the way I have been in the trade for 30 plus years and am not easiy impressed.
    John
  • kevin_5
    kevin_5 Member Posts: 308
    John Abbott mentioned Kroil, I've heard it's good, but never had the opportunity to try it. The stuff I like is called "PB Blaster". I restore antique gas engines for a hobby, and have removed pistons and bolts that were really stuck. I read somewhere that the 4 ways to remove rusted bolts are chemicals, heat, impact, and torque. #1 I first soak them, #2 then with a light hammer, rap it sharply a few dozen times to break loose the rust. #3 I then apply torque. If it moves at all you've got it, but you must move it back and forth little by little as you feel it "releasing" otherwise it will tear the threads out. If that doesn't work, I heat it with an acetylene torch red hot if possible and repeat step #3. Sometimes it will move back and forth till the red goes out of the iron as it cools, then you must heat it again. #4 a cheater bar can help or hurt your situation. Be careful! Sometimes a pneumatic or electric impact wrench will help by doing #2 and #4 at the same time.
    Also you can sometimes use a nut splitter or even just a sharp chisel to "stretch" the nut a little. Just chisel a good gouge into the flat of the nut parallel with the bolt.
    If despite your best efforts the threads in a hole get messed up, "heli-coils" are a wonderful way to rethread the hole to standard size. If you can drop your part into a bucket of water with washing soda in it, a small battery charger will remove the rust by ELECTROLYSIS. Kind of like "un-plating" something. This is far more gentle than any of the above, but is rather limited in size. This method can be seen on Harry's Old Engine website.
  • George Berkeley
    Heat and oil?
    If you have a snapped bolt, or any fitting that is a bear, do you use oil and heat?
    For example, if I know that I am going to heat it with a torch, do I need to soak it with WD-40 or what-not first?
    Since I'm going to fire the torch, is the oil step just a waste of time, or does it really help?
