Replacement convector elements for steam system
Domenic Argentieri
Member Posts: 1
I need to replace 3 steel convector elements due to leaks, in a two pipe steam system. The sizes are 3', 4' and 6' by 6". The convectors are built into the walls, with a grille at the bottom and adjustable opening cover at the top. There is no steel cabinet as these were builtin.
Any supply houses/companies in the South Jersey/Philly area that carry this item? If not, how about North Jersey/NY area? Email or call 856.914.0624. THX.
- 112.8K All Categories
- 81.2K THE MAIN WALL
- 2.5K A-C, Heat Pumps & Refrigeration
- 37 Biomass
- 394 Carbon Monoxide Awareness
- 2.7K Controls
- 1.4K Domestic Hot Water
- 3.8K Gas Heating
- 101 Geothermal
- 133 Indoor-Air Quality
- 2.4K Oil Heating
- 32 Pipe Deterioration
- 582 Plumbing
- 4.3K Radiant Heating
- 334 Solar
- 12.3K Strictly Steam
- 38 Water Quality
- 11 Industry Classes
- 53 Job Opportunities
- 8 Recall Announcements
