How critical is the 18 inches
There are ways to get around the air separators....
I tried this out on the last injection loop system I out together and I think it works well. Not very hard to figure out if you think like water, however you need a little room. As you may see from the pic, the injection loop enters the secondary loop from above, and it is good pratice to keep at least a foot of straight pipe before and after the closely spaced t's. I did the initial purge, then ran the pumps without heat for about 20 minutes and the air was gone out the spirovent. WOuld have used a regular air scoop except for the clearance problem, no room for much straight pipe before the air separator inlet. I have to go back and wire up the Tekmar goodies next month!!
Cripes, I just noticed that the pics I took were way under exposed, I should have known when the flash wasn't that bright.....Will go back soon for better pics.
Casmo
Dependable P.H.C. Inc.0 -
They cost just as much as a Spirovent and I don't think they are nearly as nice!0 -
IN THE BOILER AIR SCOOPS
Can be purchsed from Bell and Gosset Distubutors.
These puppies haave been around for mopre than 50 years. The air eliminator is piped directly into the boiler.
Jake0 -
Jacob,
If your are refering to the B&G Airtrol Boiler fittings, B&G has stopped making those. This from a B&G/Bornquist Rep
at a B&G mini class I attended a couple of months ago.
Glenn Harrison Residential Service Tech
Althoff Industries Inc. Mechanical and Electrical Contractors
Crystal Lake, Illinois0 -
minimum pipe run
The EAS has no minimum pipe run requirements.
The Air-Trol Boiler Fittings are no longer available from
Bell & Gossett.
Dan Schaffer - Bell & Gossett0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
