Schluep fittings
Steve Minnich_1
Member Posts: 127
Schluep fitttings
Can I get some feedback and/or opinions on theses fittings. I just did a four story home using a whole lotta
WM AlumiPex and I'm not crazy about their screwed fittings--it seems like you're wrenching forever with those things.
I already own the Shluep 5/8" and 3/4" fitting tool so that is not an issue.
Thanks in advance for your help.
Steve Minnich0 -
Schluep fitttings
Steve Minnich0 -
Big fan of Schluep
I own the 1/2, 5/8" and 3/4" tool. Weil McLain recently took on the SFI fitting system . Prices and availabilty should be better.
I have a few modifications, of course. The 5/8" cone by 3/4" fitting sweat can be drilled with a 5/8" bit. Now one fitting fits both 3/4" and 1/2" copper tube. This cuts down on inventory.
Also the 3/4" cone X 3/4" MIP can be drilled with a 7/8" bit. This allow the fitting to be sweat on 3/4" copper.
A nice fitting for all types and brands of tube. Wholesalers in my area only stock 3- 5 thousand feet of tube. If I get a spur of the moment job I often end up with three different brands of tube on one job
I prefer the SFI to the 3 piece compression/ o-ring style fittings. Less pieces to drop in the dirt and keep track of. With a little heat from the torch the fitting can be removed and reused also.
hot rod
Guys
you both know how I feel about these fittings but let me say it loud and say it proud THESE FITTINGS ROCK. Steve I know you bought the schluep stuff from us and I hope you found them as fast and freindly as HR. We sell a bunch of these as well as our own custom cut manifolds with Dahl ball valves and Schluep fittings already installed.
SFI Fittings
Steve,
Schluep (SFI) fittings are terrific fittings -- but currently are not endorsed for Composite (AlumiPex or any other ASTM F1281) tubing.
We are testing SFI fittings w/ AlumiPex & hope to endorse that combination in the future.
I promise that I'm not going to turn this into a self-serving commercial ... but, I will say, SFI fittings are one of the few fittings that will work w/ ANYBODY's tube -- because they are not ID/OD restricted.
Bill Wright
Manager, Radiant & Plumbing Systems
Weil-McLain0
- 85.9K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 78 Chimneys & Flues
- 94 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 59 Pipe Deterioration
- 883 Plumbing
- 5.9K Radiant Heating
- 377 Solar
- 14.6K Strictly Steam
- 51 Water Quality
- 40 Industry Classes
