Steam Question
Henry_3
Member Posts: 6
Well-- I "fired up" the ReDesigned Dry System to the Now Wet System BUT I am concerned because the Radiators and the main Pipe took a MUCH LONGER TIME to heat than with the usual Dry Return System. Is Something Wrong here?? My radiator valves never even started to vent. I waited about ten minutes and decided to shut it down. Besides the solder joint at the beginning of the condensate branch pipe {just off the main heat pipe sprouted a leak. Is there any way I can braze my copper 1 1/4 fitting to the original black pipe stub using my turbo torch and maybe some mapp gas ???
Traditional steam versus Vapor
What is the difference between a traditional steam and a vapor steam system? What is the role of the Vaporstat?0 -
where's the vent?
Sounds like you didn't vent what remains of your dry return, so all the air is being pushed through the rads. You need a vent where the dry return drops into the wet one.
I'd say you need a pipe threaded copper fitting to make that transition.0 -
Vapor systems let you run at much lower pressure. The Vaporstat is just a more sensitive pressuretrol with lower cutouts.0 -
vents on vapor
there are usually trapping and venting differences -- vapor systems have one big main vent ('air eliminator') on the dry return near the boiler; no vents on radiators -- and there is a trap or some other contraption (emphasis on 'contraption'!) at the radiator outlet to let air and condensate out, but not steam.Br. Jamie, osb
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
