Jamie's cottage
Unknown
Member
I went to visit Jamie Hall in Connecticut this weekend, to look at his vapor system in his cottage. The cottage is split into halves, heating wise. One half is valved off and not used. It is all still there, but unused. The system is a Hoffman with a Hoffman Loop on it, still.
the boiler
The boiler has been changed, and the new one was just stuck in, but it works. The boiler is sized to just do half of the house. The pressure is controlled by the vaporstat, so the Hoffman Differential loop just sits there doing nothing.0 -
Hoffman Differential #0
Jamie wont part with it, though. I can understand that. Im trying to find out what the height of the waterline is supposed to be with this old system. It can stay if it is understood and not messed with (waterline-wise).0 -
header
Looking at the Header, an old Smith used to be there. Jamie has a plan to get the whole system back to working condition. He needs to chew up some floor to replace some returns, cut in a couple valves, and install a new boiler (and maybe some more work).0 -
hot air
This house has been in the family for well over 100 years. 80 some odd years ago, someone sold to them the idea of wet heat, this vapor system. Im not sure they were completely convinced, because there STILL is a working gravity warm air by coal furnace in the next room. There is still coal in the bin. I couldnt believe my eyes! A one hundred plus year old furnace sitting there, waiting to be lit. Its not going to be lit, though, because WET HEAT RULES!!!!!0 -
the rest of the house
I wish I lived closer. This project is do-able. It could be fun, too. Jamie, I hope someone links up with you to do this project. Let me know how I can help.
Noel0 -
Thanks, Noel
for coming by and taking a look at the place! It was a real pleasure to meet you.
Now to get some pipe twirling done...
JamieBr. Jamie, osb
Here ya go, Noel and Jamie
piping diagram for the later Loops, showing max height of waterline.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
