steam latent heat
Rick T
Member Posts: 16
Why does the latent heat of vaporization of steam go down as the pressure increases? You would think it would take more energy to jump off the surface under more pressure.
because
the boiling point of the water (sensible heat) goes up. If you add the two numbers together you'll see that there's really not that much more total BTU in higher-pressure steam than there is in lower-pressure steam. The temperature goes up significantly (for the purposes for which we use it - cooking, process, etc.) but the BTU content isn't that significant.Retired and loving it.0
- 84.3K THE MAIN WALL
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 44 Chimneys & Flues
- 1.8K Domestic Hot Water
- 4.8K Gas Heating
- 120 Geothermal
- 156 Indoor-Air Quality
- 3.1K Oil Heating
- 58 Pipe Deterioration
- 799 Plumbing
- 5.5K Radiant Heating
- 371 Solar
- 14.1K Strictly Steam
- 3.1K Thermostats and Controls
- 39 Industry Classes
- 80 Job Opportunities
- 22 Recall Announcements
