terminology Chuck Shaw
chuck shaw
Member Posts: 584
If using the term, "direct vent boiler", either gas or oil fired, when ordering a heating appliance, what would you expect from your supply house? Just curious, seems I have caused some confusion for my local counter man
Chuck
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=143&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Chuck
Direct vent
means direct vent. An appliance that requires no chimney and no powerventer. The appliance is factory approved or listed for direct vent. Am I close ?0 -
Direct vent implies that the appliance both exhausts and gets combustion air via piping to the atmosphere.
Indirect venting implies that the appliance exhausts directly to atmosphere while utilizing indoor air for combustion.
Direct Vent
The difference between Direct Vent and Mechanical Exhausting relative to code is what is confusing. Some people think they are one in the same. They are not, Direct Vent has different clearance to windows, doors and openings. Under 50,000 BTU's 9" over 50,000 12" (that may change with new code and give more options).
The appliance vents flue products to outdoors with out power vent, and gets air back in from outdoors, in some case by using a concentric vent in other cases two seperate pipes. The direct vent equipment may have a "Combustion Air Blower" but does not pressurize the vent. Mechanical exhausting uses a power venter and every part of the vent pipe is positive pressure after the power venter and must be sealed. It must be terminated 4' from windows, doors and openings. I find there is much confusion on the part of many in the trades and even some inspectors. The best way to know is to read the installation manual and look at rating plate to see if classified "Direct Vent" I also have a Troubleshooting Guide that clears this up.0 -
Direct vent versus power vent, etc.
To add to the confusion, there is equipment available that is wall vented, but does not use a fan for exhaust...ie some newer gas water heaters and gas fireplaces.
Boilerpro0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
