HPWH damper for inside or outside discharge
hot_rod
hot_rod Posts: 28,840
I believe that is the plumber that came up with the idea for Rheem
    EdTheHeaterMan Posts: 13,052
    You got to love it when they put their name on it. It must be official!
    ethicalpaul Posts: 9,107
    so the idea is that you send the cooled exhaust air outdoors so it doesn’t cool your home in the winter?
    And what air replaces it?
    It doesn’t seem like a good idea
    this shows the intake ducted in. Obviously assembled as a demonstration since no water or power that I can see.
    Intake too could have a damper if the space can provide adequate cfm
  • Kaos
    Kaos Posts: 1,016
    @ethicalpaul Yup, terrible idea. I doesn't work in the winter because that air you exhaust can only be made up by outside air infiltration. That outside air is COLD, so the net loss is quite significant.
    Assuming no hot boiler, the best spot to dump cold air from a HPWH is behind your fridge. Heat rejected from the fridge will help to heat up the cold discharge air plus the fridge is now working against a lower delta T, so it uses less power, win/win.
