Weil-McLain Backorder Problems
Hello all - we are having a new Weil-McLain SGO 7 installed in our home. The contractor that is installing the SGO has been delaying us for over 2 months. They were supposed to install the boiler in mid-September but they said they cannot get a part for the boiler. Is this normal? I called Weil-McLain and they said availability depends on the distributors and they cannot check part availability even though they are the manufacturer?!? I gave the contractor a deposit of $4000 and keep getting told the part is on backorder till a future date. What do you all think? Any one else experience this problem?
  • patrykrebisz
    patrykrebisz Posts: 176
    Weil-McLain = Williamson (at 2/3 of the price)
    ethicalpaul Posts: 9,101
    Sounds more like a contractor cash-flow problem than a part backorder problem. Ask what part
  • BobC
    BobC Posts: 5,584
    You should not have paid that much down, at this point I suspect the contractor might be trying to bilk you. Te;; him you want your money or the boiler.
    Bob
    3PSI gauge
  • Mad Dog_2
    Mad Dog_2 Posts: 8,766
    edited 4:31PM
  • Operadox
    Operadox Posts: 5
    Can't say how common it is for that boiler, but two months with no install date is long enough to ask for proof. Ask the contractor in writing for the exact part name and number and the supply house it's on order from. Weil-McLain only sells through wholesale distributors, which is why they told you to ask the distributor. With the part number you can call that supply house yourself, or ask Weil-McLain who distributes in your area, and hear the backorder date from them directly.
    If the story doesn't hold up, send the contractor a dated email or letter with a firm date to either install or return the deposit, and keep copies of everything.
