Can thermal imaging help narrow down where to open a wall for a suspected hidden leak?
I’m helping a friend look into a possible leak near their bathroom. There are no obvious water stains on the walls or floor, but one small area always feels colder than the surrounding surface. Opening everything up right away could turn into a much bigger job than necessary.
I’m planning to scan around the toilet, shower, and adjoining walls with a Thermal Master P1. The goal isn’t to immediately identify which pipe might be leaking. I’m hoping to find areas that look different from the surrounding surfaces first, then decide where it makes sense to investigate.
For anyone who works on plumbing or radiant-floor heating, where would you look first when there are no visible signs of water damage? Has thermal imaging helped you narrow down the area before opening a wall?
  • ratio
    ratio Posts: 4,348
    I'm completely sold on thermal cameras as a diagnostic tool. I use 'em on radiant floors looking for leaks, electrical connections and panel boards looking for hot spots (bad connections), & building envelopes (heat loss/infiltration).
    Plus, the grandkids like to use it (very closely supervised) too!
