Very early Johnson Control Compressor
This may be obvious but I am not a compressor guy. I have a very old pneumatic control for out main building. A few years ago I replaced the tank, it had a leak. Well now it seems the compressor is not compressing. It hasn't stopped running since I turned it on a few weeks ago and it's barely getting up to 10psi. I find no air leaks. Does this mean the pump is no good? I haven't made any attempt to repair it other than check the oil and that's all good. Is there anything I should have a look at before I replace it? The thing is near 80 years old and I'd love to repair it.
i'd disconnect the outlet of the compressor and see if you observer/feel pressure there if you put your finger over it. if the inlet is plugged it won't pump too. usually they are just a reed plate for the inlet and outlet valves. a stuck valve or broken valve or debris in a valve will keep them from pumping.
make sure it actually is the pump and not a leak in some control or something like that.
1 -
Thank you. I soaped a few of the fitting and did find a leak but fixing that made no difference. I'll check the inlet and outlet and the reed plates.
I've had reasonable luck with the Harbor Freight air pumps. For the cost, I can replace them every few years & still be in the black compared to the Quincy. If you go this route, you may have to rework the connection to the new pump, on mine the flare connection was a different specification (not size).
- 135 Chimneys & Flues
- 16.2K Strictly Steam
