Buderus Blueflame conversion to gas
billybob5
in Gas Heating
i have a Buderus G125/21 BE could some one suggest good gas burner to change over Thanks
Since its an obsolete burner, a call to Buderus might help. The Beckett CG4 and the Carlin EZGas Pro both show OEM setups for the G115, which is the same block as the G125BE. I'm sure baffles would need to be removed or adjusted to get the stack temperature over 350° net. They'll have questions about venting, too. Lined chimney? Direct vent? Double acting barometric relief with spill switch in the future?
2 -
- 135 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
