Peerless oil boiler
rdc
rdc Posts: 1
I'm installing a peerless wbv e oil boiler, with
Rear flue. It has baffles in the boiler. It seems that they block 1/2 of the 6" flue. Should I take them out? Or leave them? Thanks .
  • Ironman
    Ironman Posts: 7,975
    Removing the baffles will lower the efficiency but raise the stack temperature. It should only be done if the chimney requires a higher stack temperature to achieve proper venting.
    Bob Boan
  • HydronicMike
    HydronicMike Posts: 471
    It’s probably too late, but why the peerless?
