Sight glass is low (1/5 level). How to refill without cracking boiler?
I did a few blowdowns without refilling.
Sight glass is around 1/4 high.
Boiler never cold b/c heat and hot water.
What's the best way to refill this back to 1/2 or 3/4 level? (What is ideal level?)
Thanks Matt. I'll just add 5 seconds every few hours. Few times should do it.
Get it to 1/2 ?
Part of routine maintenance, for customers, involves firing the boiler, draining it all the way down, and refilling it. I have done this to more boilers than I can possibly remember, and none of them have cracked. Only way to crack a boiler by refilling, is if the boiler was running on empty, and is cherry red
2
