Main air vent
A simple question, but the answer I think might back “it depends.”
How do I know when it is time to change the main air vent? Are there any signs or clues I should look for that indicate it needs replacement?
    109A_5 Posts: 4,759
    Mostly if it does not close with the presence of steam. Also I suppose it if becomes restricted due to corrosion, etc.
    ethicalpaul Posts: 9,076
    yep it has to vent air and not steam. But I’ve seen them failed closed that you really couldn’t tell from in the living area of the house
