Insulation for steam pipes in basement
For my project this year, I am going to insulate the pipes going-from and returning-to my steam boiler. Should have done it years ago but never got to it.
I went on supplyhouse to look for some but they don’t seem to carry fiberglass, just something called “k-flex” which they claim is rated for 300F. It appears to be EPDM based. Is it OK?
What does the brain trust here recommend? Is online good, or is this something I should collect in person?
I think a previous owner had asbestos, but that was long gone before I got here. So now I have a chance to do it right.
@EBEBRATT-Ed any sense in using 2" insulation for better results? Does the fiberglass and PVC come in this thickness? Thanks
it comes in many thickness. There comes a point where you never get the return on investment so is it worth the extra $’s?
IIRC looking at the curve of cost effectiveness of insulation, the elbow was right around 1 1/4 to 1 1/2 inch thick. If your energy costs are high, then going thicker might be better. However, you still need some heat in most basements, so I have found using one inch on steam mains and leaving the branches and fittings uninsulated provide a good heat balance. In boiler rooms I try to cover just about everything, since these spaces tend to be warm and the heated air is lost up the chimney very quickly
To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
OP here just wanted to report back. I spent an afternoon insulating my steam pipes in the basement both source and return. (Got them shipped from the place @pecmsg recommended). It was 1 inch thick fiberglass.
Wow!
I wish I had done this years ago but I was too lazy. The upper floors heat up great now. I actually do have some of the bigger pipes near the boiler left to insulate (wanted to get the straight long runs taken care of first). The difference is amazing and immediate.
Thanks everybody!
2 -
I use 2" on the mains and 1" on the runouts and returns. Seems to work well for me. I buy them at buyinsulationproducts.com.
