Installing circulator to boiler
External circulator to supply water to boiler in residence. Its a smaller Taco pump , one of the options recomme ded in the install manual. I want to mount the pump in an orange pex line either a foot away from boiler vertically, or three feet away horizo tally. I am concerned about weight on the pex pipe, I think its too much weight. I can build supports but any ideas or comments are welcome
  • Use hard pipes or copper from the boiler to the pump location. That should be enough to hold the pump in place. Don't ever put a pump, or any other hydronic accessory like air scoops or flow check valves between 2 pieces of PEX tubing. It is not designed to support the weight of anything. You will surely see sagging and eventually develop a leak or even separation of the PEX from the fitting it is attached to, over time. Besides it looks so amateur and screams "I have no idea what the H*** I'm doing"
    mattmia2plumbworker
    EBEBRATT-Ed Posts: 21,190
    Or use black pipe nipples on each side of the pump. Use split ring pipe hangers with 3/8 threaded rod with nuts and F & M plates (ceiling flanges) to mount the pump to something substantial
    GroundUp
    hot_rod Posts: 28,544
    A pump to supply water to a boiler? Circulator pumps mainly circulate water in a closed loop system. What type of boiler is this? Any pictures?
  • Hot_rod: Rianni residence boiler, there is no circulator in the boiler cabinet, so install manual shows an external pump going into boiler. Water comes from a spaced-T to the boiler then back to a loop circulating throughout the house. I hope this makes sense now. I forgot the model number, I beleive it is 90k btu boiler, condensing type. We are replacing the Weil McClain boiler.
    EdTheHeaterMan Posts: 12,880
    edited September 2025
    semantics. This post screams "I have no idea what the H*** I'm doing"
    mattmia2 Posts: 18,254
    do the near boiler piping in hard pipe, either copper or black iron. the fittings for pex will be very expensive and it will look terrible.
  • Ok, very good suggestions based on the topic. Much appreciated. Will post a pic when I am done. Take care. Thanks for the help!
