What size couple old brass
I have an old underground water line 3/4 thick wall brass pro press and shark bite won’t fit over it I need to get a coupler to connect it to CTS maybe a compression fitting?
Compression or thread the end.
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
I’m thinking this our water company uses them I don’t own a pipe threader I can get into that hole I’m not sure but think this is what’s originally on there
MegaPress for water (not gas). Rent the tool.
I own two pro press and have mega press jaws but question is will a 3/4 mega fit over the outside of this pipe because a sharbite does not
@mattmia2 yes correct a 3/4 wouldn’t fit over but I’m sure an ips 3/4 would I can try mega press or that pack connector but I’m out of both the customer will have to wait until Monday everything is closed who would have those in stock and my buddies are out of them thx
it looks like there is a sharkbite designed for pvc that is ips but the outside might not be smooth enough for it to seal.
you could thread it but old brass tends to become brittle so it might crack if you try to do it with a die. a thread mill could probably do it but those aren't exactly portable.
1 -
You can buy a IPS water service adapter that will fit right over the brass. You need to make sure you specify IPS and not copper or else it wont fit over the pipe.
Boy that would be confusing in a dark awkward with those wrench flats.
