Water leak problems installing cast iron baseboard
We installed a bunch of Burnham cast iron baseboard by request of the customer during a complete remodel. We filled the system last week & came back to a bunch of water leaks at the push nipples. One leak was in the casting itself. We installed as the instructions specified. Did we miss something, is there something not included in the instructions, is there some secret trick, is this bad quality control?
The last cast radiator I installed had a leak in the middle of the casting. Had to replace it.
We used the tool rented from the supplier. It seemed awfully loose & worn out & slipped at the end causing whoever used it to punch the fins on the back of the cast baseboards with all their weight. We got a different one when we re-did them & felt a more definite closure this time. But we couldn’t get a consistent answer on if the push nips should be dry or have something added. About half say don’t add anything, others say use dope, some say graphite, maybe it depends on brand?
Why not just follow what Burnham says? They have clearly written instructions for how to do this.
2 -
I have no clue, but if it was me I'd use either pipe dope, or cutting oil, or tapping oil, way lube etc. They just want some lubrication when going together. If you have cutting oil or tap oil (tap magic, rapid tap etc) that would probably be best.
1 -
looks like we have more bad castings.
Burnham/US Boiler Rep always had nipple lube for us to purchase, still have cans around probably. We always cleaned the ports and nipples and wiped out, then lubed lightly the port & nipples. Assembled and pressed, always paid close attention to even pull together. We did have a few doa sections from factory over the years but hundreds of feet of baseray usually went ok. Dry press together not good. Also usually little rust in the ports from sitting around. Hope goes better for you.
2
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
