1 pipe steam returns hot?
Is it normal for the returns after the main vents to get warm during long cycles like we are having now with the cold in the northeast? I had re-pitched a return that had some obvious sags and low spots, I’m noticing the return pipes must be getting some steam traveling back through them?
Radiators are filling fully, no signs of pressure.
  • Paul S_3
    Paul S_3 Posts: 1,297
    Dry and wet returns will get warm and eventually hot. It's water that condensed from the steam. Are you having issues with the system like water hammer etc
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
    Jamie Hall Posts: 27,737
    If these are steam main extensions — sometimes called returns — that is to say they are directly connected to the steam mains, no traps or whatever — of course they will get steam in them. Slowly, perhaps, if there are no vents, but inevitably.
  • Kjmass1
    Kjmass1 Posts: 294
    thanks- no traps, just a step down in pipe size from the main to the smaller return extension pipe back to the boiler.
    Guess I was surprised they would get that hot even all the way back to the boiler. Worth insulating those?
    EBEBRATT-Ed Posts: 20,938
    @Kjmass1 I am assuming this is overhead piping. Is your vent located at the end of the main where it joins the return? Or back by the boiler?
  • Kjmass1
    Kjmass1 Posts: 294
    correct, ceiling of basement. Vent is located at end of 40’ steam main (a couple of big gorton vents). No venting at the boiler. The other 20’ main doesn’t have a main vent to try and slow that side down.
