Johnson control training
I am encountering Johnson pneumatic controllers every day. Some work, some seemingly do not. Some respond intuitively and some do not.
Beyond adjusting a setpoint, where can I find learning opportunities to expand my knowledge of my physical plant? I want to troubleshoot an unresponsive controller and calibrate equipment and sensors downstream. The organization has few control technicians who respond to dozens of buildings and may take 2-12 weeks to make repairs in my plant.
My immediate employer is eager to bring additional practical knowledge in-house. Johnson Controls has not updated their training opportunities since 2020.
What are the options to learn more about controls?
    EBEBRATT-Ed Posts: 21,365
    I don't know what Johnson is doing now but they used to have great training. Pneumatic controls are old technology now but there are still a lot of those system out there. I used to be leery of them when I didn't know how they worked. But it is not difficult to learn the basics which is all you need 80-90% of the time
    Honeywell, Johnson, Powers & Barber Coleman used to have pneumatic equipment. Although the controls differ slightly between manufacturers once you learn 1 system you can work on any brand, and you can mix and match controls in the same system if your in a jam.
    Google "National Energy Controls Corp" they are in PA and offer pneumatic training.
    Kele associates in TN sells controls I don't know if they offer training
    Tommi68
  • Tommi68
    Tommi68 Posts: 56
    We have some Honeywell, but predoninantly Johnson Controls. Of the 12 I looked at today, only 5 responded to a change in setpoint.
    Should have mentioned that I am looking for training in Toronto, Canada.
  • https://www.johnsoncontrols.com/services-and-support/training-services
    @Tommi68
    Don't know about Toronto. PA is not that far.
    I would ask the distributor where you buy your controls.
  • ScottSecor
    ScottSecor Posts: 1,083
    I was looking for something in the Heating Help library and came across this, hope it helps.
    https://www.heatinghelp.com/assets/documents/183.pdf
    ratioTommi68
    @ScottSecor
    That one is high mileage but it still works the basics do not change!
    Tommi68
  • ratio
    ratio Posts: 4,347
    …a bi-wood humidistat. My mind popped out of gear for a second, but it made perfect sense once I got it back into gear.
    Tommi68
    mattmia2 Posts: 18,437
    That doesn't seem very durable. Don't know what their aversion to saying cellophane was.
  • Tommi68
    Tommi68 Posts: 56
    Johnson's "Modern' replacement seems to be the vintage of my equipment.
    Ill devour this and see what is still operating, it is getting tiresome manually throttling valves while the outside temp swings.
