Return pipe
Bcclew
Bcclew Member Posts: 2
Should this pipe be on an angle going back to furnace? Thanks
  • delcrossv
    delcrossv Member Posts: 2,204
    Need a little bit more information.
  • Bcclew
    Sorry about that the small diameter that goes from end of system back to furnace
    109A_5 Member Posts: 4,346
    Pictures would help. Furnace, Forced air heat ? Or steam heat, condensate returning to a boiler ? Boiler pipes most often have a pitch to them, since gravity will help move the water.
    Jamie Hall Member Posts: 27,697
    Is this a true dry return for a two pipe system, or a steam main extension — often referred to as a dry return — in a one pipe system?
    EBEBRATT-Ed Member Posts: 20,827
    We would like to help but none of us are equipped with x ray vision.
