Boiler flush
plumbit
plumbit Member Posts: 21
the above boiler does some infloor heating in a garage. The water is really hard. It’s about 4 years old now. Just wondering if these boilers new a flush with a descaler solution like a tankless hot water heater?
    hot_rod Member Posts: 28,010
    There should not be much water being added above what you filled with the first time.
    Ideally the system is cleaned and flushed when first installed. With a hydronic cleaner.
    Then water meeting this IBC spec should be put into it.
    Officially if the water doesn't meet this spec you have no warranty.
    You could still run a cleaner and flush. You would want to check you water for at least hardness, TDS and ph.
    You can buy a single use filter to fill the boiler with if you water is too hard or high TDS. Here is an Axiom example
  • plumbit
    thank you for your detailed reply. Just reading through the information and I hope I’m understanding this right. If I got that filter. Could I just cycle the water that’s already in the system through this filter?
    The water in the system may have a lot of crud, rust, scale, teflon tape, etc. I would start with whatever potable water you have? City or well?
    It depends on how bad the water us. I have seem system water run through a basic cotton micron cartridge filter to get the solid debris out.
    If you do run a cleaner it will break loose a lot of gunk in the system. Best to flush it out, start fresh. Water's cheap.
