Need help with figuring out what this component does.
    mattmia2 Member Posts: 17,122
    That's a vapor system. What does the plate at the top say? What valves and return connections do the radiators have?
    Steamhead Member Posts: 18,603
    It's a damper regulator. That's either a Broomell or VECO system. Post some pics of some original radiator shutoff valves and return fittings and we can tell you which.
    Consulting
    mattmia2Long Beach Ed
  • Waher
    Waher Member Posts: 373
    Low pressure gauge that uses a water column to indicate the operating pressure. You likely have a vapor system.
    EBEBRATT-Ed Member Posts: 20,344
    Don't know but it is measuring pressure in ounces. Says so on the side. Is it permanently hooked to the system??
    Jamie Hall Member Posts: 27,484
    Does look like a damper regulator from a coal fired boiler. Any interesting pulleys on the overhead?
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,843
    edited January 2025
    Looks like a Broomell. I believe there was a big float ball (maybe still) inside that operated the boiler damper via chain and pulley to control the coal fire and thus the pressure.
    If the system's still intact, the boiler pressure is now regulated with an electric vaporstat switch.
  • Masonsair
    Masonsair Member Posts: 3
    I thought this was set up as a steam boiler. It is a broomell. What’s the difference between a vapor vs steam heating system????? Thanks everyone
  • delcrossv
    delcrossv Member Posts: 2,204
    Vapor is ultra low pressure steam heating. Usually the radiators aren't even trapped in a conventional way, but rather have water seals. Running these over a few ounces causes problems.
    @Masonsair , get this book- Broomell and other Vapor systems are in chapter 15:
    https://www.heatinghelp.com/store/detail/the-lost-art-of-steam-heating-revisited
    Consulting
  • Masonsair
    @Steamhead thank you I judged ordered it
    delcrossv
