90% Air temp Furnace, Do I need a horizontal kit, the vinyl tube is sloping the wrong way.
Guzlos87
Member Posts: 1
in Gas Heating
You need to follow the instructions. That drain from the collector should be at the bottom. Water doesn’t flow uphill.
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
